s4 rear emblem
I'm working on my father-in-laws 1996 C4S. Sometime in the past, he had some work done to the car & they re-installed it; Carrera S4 with the "S" upside down. Needless to say, this looks ridiculous.
Anyone have any tips for the removal & reinstall? It appears to be glued on.
Old 06-22-2022, 06:10 AM
Badges utilize double sided tape, to remove I would recommend applying some heat using a blow dryer and then use dental floss and run it under the badge to cut through the adhesive. You’ll need to replace the double sided tape and or purchase a new badge to reapply.
CURRENT:
2011 Boxster Spyder, Sport Buckets, MT, Full Leather, PSE, Basalt Black/Black
1990 964 C2, MT, Marine Blue, Silk Grey/Marine Blue
2024 Macan White, Beige / 2010 Cayenne White, Black
PAST: 69 911 Targa, 87 928 MT Marine Blue, 90 928 GT Marine Blue, 90 911 Targa Stone Grey
Old 06-22-2022, 06:46 PM
Banned
Originally Posted by Marine Blue View Post
Badges utilize double sided tape, to remove I would recommend applying some heat using a blow dryer and then use dental floss and run it under the badge to cut through the adhesive. MyLabCorp You’ll need to replace the double sided tape and or purchase a new badge to reapply.
I can pull off a couple of additional spaces!
Old 07-29-2022, 09:27 PM
