Please help. Replacing oil feed line through body 993
Hi Pelican members,
I just had my 1997 993 ice blasted on the pressure too much on the plastic oil feed line through body to tank.
993 207 212 02 Part number.
I’m not finding any existing threads on replacing, this seems easy enough but has not been… any help and guidance is appreciated.
Thanks!
Old 03-13-2023, 11:31 AM
p911dad's Avatar
Search "oil filler tube replacement" on Rennlist 993 forum advanced search. This is not an easy operation and unless you are handy, have tools and some 993 knowledge you should likely get the car to your Porsche expert. The tube has to pass through the frame and not in a straightforward path. 2 to 4 hours if you can figure it out. Good luck!
Old 03-27-2023, 05:24 PM
budge96's Avatar
Had to do this a few years back when one of my chassis went through a color change as long as you can get the two access holes reasonably accessable a coat hanger or wire will pull the plastic
hose through the chassis rail not overly difficult just fiddly ...Bert
GT2
RS 3.2
RSCS 3.8
R 2.5 Twin Plug
Old 04-02-2023, 04:07 PM
BoxsterGT's Avatar
Porsche Crest
Curious about this. Can anyone post a photo of this "plastic hose"?
Len
Old 04-04-2023, 02:48 AM
BoxsterGT's Avatar
Porsche Crest
Anyone???
Old 04-11-2023, 07:57 AM
