Power Reclining seat stuck forward
I've got 993 seats in my 82. I powered the passenger seatback all the way forward and now it will not return back to a reclining position. The switches are good. Any advise as to how to get the seat to recline? The seat is out of the car on the bench.
82 911SC
Old 05-19-2023, 10:52 AM
Wish I could help. Maybe run power direct to the switch
Old 05-28-2023, 12:19 AM
Sounds like it is jammed You can disconnect the motor from the tracks the you can turn each side by hand make sure they are even then hook your motor back up
Old 05-30-2023, 02:32 PM
My guess is it is the switch, mine are bad to. Sprayed some crc and got a little movement then stopped again. I read you have to disassemble the switch and clean the contacts, springs, and ball bearings inside. Haven’t gotten to that yet
Old 05-30-2023, 07:18 PM
Thanks for the reply's. The seat back was stuck all the way forward. I took a small wrench that fit the pivot pin and applied a little pressure to each side of the seat. It was enough to free up the the works and the seat now functions normally. Thanks again.
82 911SC
Old 05-31-2023, 06:25 AM
Did you see what caused the seat to lock up?
CURRENT:
2011 Boxster Spyder, Sport Buckets, MT, Full Leather, PSE, Basalt Black/Black
1990 964 C2, MT, Marine Blue, Silk Grey/Marine Blue
2024 Macan White, Beige / 2010 Cayenne White, Black
PAST: 69 911 Targa, 87 928 MT Marine Blue, 90 928 GT Marine Blue, 90 911 Targa Stone Grey
Old 06-03-2023, 08:37 AM
