engine support gearbox out
what is the best solution for support engine so you can move the car with gearbox out?
that was easy on the 996 cars but how about the 964? |
Not very feasible.......
Very different on 964 and have had to just pull motor if you need to move it.
Stan D |
gearhead
It’s kind of difficult to remove the gearbox without the engine on the air cooleds. Doing that was designed into the water pumpers. Best to just pull them as an assembly and put the engine on a stand or pallet while you do your gearbox work.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
