915 trans
Does anyone know what size axle will fit in a 914 that has a 964 engine 3.8 L with a 915 transmission Wave track fliped ring and pinion 108 mm course splined transmission flanges and 108 mm 911 axel stubs with 6 / 10 mm bolts thanks for any info Slammin out
Old 11-29-2023, 02:37 PM
fetus's Avatar
I see you also asked on 914world. I used Swayaway axlexs.
Sway-A-way axles part number 2420 20.25” custom 930 axles is what I used with my 108mm CV's and stub axles.
PMB sells the sway-a-way axles and the lower cost empi version.
https://pmbperformance.com/collections/pors...rear-axle-axles
75 914-6GT clone with a 1995 3.6 DME motor, 915 trans with Martin Bott 916 shift kit, MB911 heat exchangers, boxster brakes, etc... Special thanks to Patrick Motorsports for fixing my 915/916 trans and there associated 3.6 conversion parts.
Old 12-12-2023, 12:12 PM
