Is this supposed to hold vacuum?
Mine does not.
Old 03-12-2025, 08:24 AM
Party Member
viejopatron's Avatar
It is the actuator for the flapper valve on the Heating Fan Blower Assembly. I would not expect it to hold a vacuum for an extended period of time. With the engine running and heating system ON, does the flapper valve change position when commanded?
Gary
71 911T Miss Demeanor / 2013 Audi Q5 Hundeführer / 1995 993 Miss Adventure
Old 03-22-2025, 06:42 AM
Old one would not hold any vacuum and flapper valve was not moving with engine running. Replaced with superseded part number Pierburg OPB 129061 OEM. Part holds vacuum with a might vac and after install the heater fan flap moves as it should.
Too bad there is not a rebuild kit for this. Replacing the original rubber with a modern silicone diaphragm would be the cheaper fix.
Regards
Old 03-28-2025, 01:11 PM
