993 Instrument Warning Lights Not Working
HELP!!!
INSTRUMENT PANEL HAS NO WARNING LIGHTS AND GAUGES ARE NOT WORKING. I CHECKED ALL FUSES,RELAYS AND REPLACED THE CENTRAL INFORMER BOX. I ALSO PUT A NEW ELECT. PART ON THE IGN. SWITCH BUT STILL NO WARNING LIGHTS. THE CAR STARTS BUT THE GAUGES ARE NOT WORKING THE ALT. LIGHT AND ALARM LIGHTS ARE THE ONLY ONES THAT WORK WHEN I STEP ON THE BRAKE THE ALT.LIGHT GETS DIM. I CHECKED ALT OUTPUT WHICH IS 13.8V HAS ANYBODY HAD THIS PROBLEM ???? PETE |
if the car is a '95 or early '96, has the rear wiring harness recall been performed??
max |
HI MAX
ITS A 96 YES THE ENGINE HARNESS IS NEW |
993 Gauge Problem
Did you get this problem fixed and how?
