Question 996 to 993 steering wheel Swap
Will a 996 wheel work in a 993?
Old 06-24-2004, 05:18 PM
maxnine11's Avatar
yes.
-disconnect battery for at least 20 minutes (to get rid of any residual voltage)
-loosen 2 Torx30 bolts from behind wheel that hold airbag in place.
-pull airbag slightly away from steering wheel unhook yellow connector from rear of airbag.
-break the 24mm nut loose on steering shaft
-center wheels, and level steering wheel. mark 12 o'clock on the shaft
-remove horn contact wires from steering wheel
-remove nut/washer from steering shaft
-remove steering wheel.
Installing the 996 wheel is a reverse procedure of the above.
max
Old 06-24-2004, 08:41 PM
Great, THANKS!! I thought it would be the same as when I pulled the air-bag wheel of my 88 951S:-) I just wasn't sure that the 996 wheel would swap over to the 993.
Thanks Again
Old 06-24-2004, 08:48 PM
maxnine11's Avatar
here is a 996 wheel in my 993. This is one with a leather airbag and gold crest. I now have a leather airbag with the silver crest...just can't find a pic.
max
max
Old 06-24-2004, 09:00 PM
ScottKelly911's Avatar
Send a message via AIM to ScottKelly911
Max, such a great wheel!!!
Gruppe B #22
Current: Biarritz White ‘01 996 Turbo GT2 look & 1972 Targa Carrera RS Clone w/3.6
Past: ‘75 911, ‘75 914, ‘76 914, ‘66 912, ‘68 912 & ‘01 Arctic Silver 996 Turbo
Old 06-26-2004, 10:21 PM
What about swapping from 996 to a 964 (both with airbags) ? Is it the same ?
eyue
85' Carrera Coupe
93' 3.6 Turbo
Old 07-09-2004, 10:48 AM
maxnine11's Avatar
eyue, the 996 wheel from from a 996 is not a direct swap, but can be done. Besides the steering wheel and airbag, you will need the steering column "clam shell" plastic covers from a 993, and the steering column shaft from a 993. Clockspring and horn contact from a 993 or 996 as well.
Lots of details in this rennlist thread: http://forums.rennlist.com/rennforums/showthread.php?s=&threadid=78744&perpage=15&pagenumber=1
Another 3-spoke wheel option would be an Atiwe wheel from FVD or other retailers. (Pelican doesn't list them, but may be able to get you one)
FVD- http://www.fvd-web.com/fvd-usa/index-usa.html
max
max
Old 07-09-2004, 05:14 PM
Seems like too much from swapping the wheels, I'll check on FVD ot may be RUF instead.....Thanks
eyue
85' Carrera Coupe
93' 3.6 Turbo
Old 07-09-2004, 08:53 PM
Max,
With your 3 spoke wheel is the view of the dash gauges, increased, decreased or the same?
Old 07-10-2004, 02:08 PM
maxnine11's Avatar
ron, the diameter of the wheels are almost exactly the same, and the diameter of the grip is very close too.
wheel straight- view is the same
wheel turned- view is a little better than the four -spoke because of less mass to block the gauges.
max
max
Old 07-10-2004, 06:05 PM
