Man of Leisure
Rockafella's Avatar
Engine Knock in 1990 C2
When starting the car cold or warm after letting the car sit for an hour or more, there is a noticable knock coming from the left side. The mechanic claims it is a collapsed hydraulic tensioner. Does this sound reasonable? How much should this cost? Does anyone have a mechanic recommendation in Orange County, CA or even LA?
Thanks,
Rockafella
Old 07-21-2004, 04:31 PM
ckrause
Guest
Posts: n/a
A '90 C2 doesn't have "hydraulic tensioners"!!! Find a new mechanic...
-CKKrause
Old 07-21-2004, 08:34 PM
Man of Leisure
Rockafella's Avatar
A little bit more info: it goes away after the car gets hot. This is maybe 10 to 20 min of running after a cold or warm (been sitting for 1 hour or more). The wrench said it was the chain tensioner not tensioning and letting the timing chain slap around. Sound reasonable? He also said it's ok to leave it. I'm not too sure about that....engine noises can get expensive.
Old 07-22-2004, 08:16 AM
StevoRocket's Avatar
I had a 3.2 Carrera which had a noisy chain due to the tensioner being a little slow on cold startup. The local P specialist changed it with the engine in place and changed the worn chain ramps. Since ut didne involve getting the engine out it wasnt troo expenive.
2018 VW Golf R 5 door + 1991 Mazda MX5 Eunos + 2010 MX5 folding hard top.
Nikon D810 SLR and a gazillion lenses.
Lumix LX3 and Canon SX720HS (40 x zoom) , Leica DLUX 109 (really a Panasonic)
Old 07-23-2004, 09:44 AM
Did you check your Dist. belt? It might be broken, that will cause a ping....
you can call Randy from Automart he is located in Orange Ca, 714-771-6120
Old 07-23-2004, 10:08 AM
ckrause
Guest
Posts: n/a
Sorry about the dumb comment about no hydralic tesioners earlier...I had a brain fart...I was thinking valves and hydralic lifters as in the 993...
-CKKrause
Old 07-26-2004, 10:33 AM
We have changed quite a few 964 chain tensioners at my shop in Ct. The early cars (89-90) seem to have more of this problem then the later .From your description it sounds quite plausible that this could be your problem
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 07-26-2004, 07:05 PM
