lazylongboarder's Avatar
Will a manual power steering rack fit in my 964?
My power steering rack leaks like a siv in my '90 C2 and am interested in swapping to a manual rack. Is this a straight forward install? And will early racks ('89 and earlier) work? Thanks a lot guys, Russell.
Old 01-14-2007, 08:56 PM
Don Plumley's Avatar
Can't imagine that an early rack would work. The RSA had a manual rack, but it's spendy.
Don Plumley
M235i
Old 01-14-2007, 10:04 PM
AFJuvat's Avatar
Early rack will not fit.
Your options are limited to a RS America Manual rack or some sort of after-market rack if one even exists.
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 01-15-2007, 05:57 AM
Now in 993 land ...
aigel's Avatar
What are you going to do with the power steering pump - which runs off the cam?
George
81 SC (sold)
Old 01-15-2007, 04:54 PM
Platinum Member
dad911's Avatar
George
You can probably just remove the belt, but I know that a block-off is available.
Old 01-18-2007, 08:37 PM
I installed a newer 993 rack. It bolts right up and is a hundred or so less expensive than the lower sales volume 964 part. I forget where I saw the threads, Pelican or Rennsport, with full instructions.
Old 01-19-2007, 02:55 PM
