Appx cost to seal early 964 engine??
ie upgrade to the improved 92-94 w/gaskets.
Old 02-12-2007, 05:12 AM
stevepaa's Avatar
How many miles? What are your compression numbers? Is it leaking oil? How much?
check this thread
http://forums.pelicanparts.com/showthread.php?threadid=314761
steve
old rocket inguneer
Old 02-12-2007, 09:41 AM
It is a car I am interested in, 116k miles, it is leaking, have not had a PPI done yet so I don't have any details on compression etc. Just trying to get a ballpark figure on resealing one of these engines.
Old 02-12-2007, 11:08 AM
stevepaa's Avatar
At that milage, it probably needs a valve job to replace valve guides which are the main wear item. Do it your self for maybe $1500. New Pistons and cylinders are min $3600.
Of course, once you tear into it, you can follow the thread above.
Also, if you have leaks from oil lines, figure another $1500 for new lines. And then there is the pwdercoating of the sheet metal, cad plating of the fasteners, etc.
Get up to $10k doing it yourself pretty quickly.
steve
old rocket inguneer
Old 02-12-2007, 12:24 PM
A local garage quoted me $6000 - labor and seal kits. They're a really good shop!
Old 02-13-2007, 04:09 PM
Don Plumley's Avatar
Sealing the engine and the leaky cylinder head fix are typically two different things.
Don Plumley
M235i
Old 02-13-2007, 09:12 PM
bigchillcar's Avatar
what, maybe a few thou to drop the motor and simply replace seals, now work or replacement of existing pistons/cylinders or exhaust valve guide replacement work i'd guess..
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 02-14-2007, 06:19 AM
