Varioram
What's the market value for complete Varioram intake and OBDI?
I'm in heaven, when I drive my nine eleven... |
Now in 993 land ...
What's OBDI?
George |
Since the only OBD1 vram were ROW, either '95 993RS or n/a RoW 993 They are sortta popular to con vert US/Can. 964 or '95 993 to vram
Now in 993 land ...
Thanks Bill. I figured it's the DME but was confused that there is actually an OBDI with Varioram. Very cool!
George |
by the way the v-ram intake and wiring isn't OBD1 or OBD2 specific. there is 1 wire to activate the resonance flap and 1 wire to activate the v-ram mechanism. So any vram can be adapted to any earlier engine
Bill, if I'd want to change intake on my 90 to Vram, can I use existing harness and DME that I have now or do I have to obtain Euro OBDI and harness? Thanks in advance.
...and still original question remains...what's fair value for VRams these days...anybody?
probably gain more for that 964 engine with a steve wong chip and a muffler bypass mod anyways...and for a helluva lot less money and trouble, rideshoot&drink.
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
Now in 993 land ...
There is a VR intake on ebay right now. Search "varioram intake." Whatever it fetches is the going rate.
V-Ram is good if you want to broaden the torque curve. Peak is HP slightly increased w/ v-ram. If you manage the rpm band (as with a close ratio gear box, there is not much to gain with v-ram). If you leave it in one gear and want it to pull across the rpm band, vram is likely worth the trouble. I think the cost for the setup is $2k ish. Heck, you could buy a complete vram engine (used) for $7k to $10k and sell the long block to recoup most of the money. That would include DME and harness. If you buy OBDII, keep some $ aside for disabling drive block, if your chassis is not compatible with drive block. Steve Weiner charges $1200 to disable. Doug
1971 RSR - interpretation |
doug, i'm thinking in terms of horsepower..that the diff's in varioram alone vs. a chip and muffler bypasses is about roughly the same. now as for the diff in the torque curve, i really don't know off hand. if v-ram gives more torque 'pull' i can see why some would desire that.
Understood. It is not really fair to compare one point on a data graph and draw too many conclusions. It would be like buying a suit based on pant length alone.
area under the torque is to most people's advantage, especially in non-racing applications. Just my $0.02. Bill's $0.02 is more valuable than mine. ![]() Doug
yeah..bill's $.02 is worth at least a couple bucks!
![]() and i agree..since i don't track, i'd rather have that fat torque under the curve.
