intermittent fan
Noticed without any apparent routine that Two controls on the heater console
Demistor button &
fan rotary, decide themselves if they will do anything or not,
when I ask them.....
is their a usual fuse or relay to wiggle about to make them work on demand again?
Nineteen Ninety One 964
Old 09-24-2007, 12:18 PM
You may be lucky enough that the switch contacts maybe dirty.
If you can open or find a way to get a contact cleaner in between the contacts, you may not need to replace them.
But you do need to do a continuity test on all switch settings with a digital or analog meter to be certain the problem is on the switches.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 09-24-2007, 02:14 PM
Just seemed tiny bit strange the both of them playing up
at same time,
and they both either work perfectly
or both don't work at all
Old 09-24-2007, 02:35 PM
