trans fluid change?
I have a 95 993 with a manual transmission. I need to do a transmission fluid change. First time I have changed it and there appear to be a lot of different gear oil brands. My trans has a quick shift installed and can be a bit stubborn going from 3rd to 2nd at times.
Any suggestion on what brand of oil?
Old 04-23-2008, 10:13 AM
Bill Verburg's Avatar
Mobil Delvac Synthetic Gear Oil 75W-90
this used to be called SHC but has been renamed.
*this is not going to be found at the local Pep Boys, Autozone etc.
Bill Verburg
Old 04-23-2008, 10:54 AM
Can one use the same tranny fluid for the 96' 993 twin turbo? Where can you purchase it?
thanks,
Old 04-23-2008, 08:38 PM
thanks,
yes, truck service shops or Lufteknic
Bill Verburg
Old 04-24-2008, 06:02 AM
kang's Avatar
I’ve always used, and have been happy with, the regular M1 75W-90 (not the Delvac).
http://www.mobil1.com/USA-English/MotorOil/Other_Products/Mobil_1_Fully_Synthetic_Gear_Lube_75W-90LS.aspx
What’s the difference between this one and the Delvac?
Downshift
Old 04-24-2008, 08:18 AM
