964 Steering pump pulley removal help
Hi,
Would like to remove the steering wheel that driver the steering hydraulic pump. (oil leak suspected).
I have the muffler out and remove the oil line in front the pulley cover, remove the cover.
I have the pulley visible but I cannot remove it (19mm wrench).
Is it a normal bolt ? right hand turn ?
Thanks in advance
Michel
Old 08-03-2008, 04:21 PM
righty tighty, lefty loosey.
Get something to hold the pulley to keep it from spinning while breaking the bolt loose.
Good luck.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 08-04-2008, 12:43 PM
