1996 tiptronic speedometer/odometer relay info
Fellow Pelicans with access to PET,
I was told to replace a relay in the front trunk central electronics box which handles the signal from the ABS left front wheel sensor that goes to drive the odometer in a 1996 tiptronic 993 coupe. I looked and could not locate this relay but saw one which is just left of the 2 relays for the headlights. By description it is a tall rectangular relay with "VDO" markings on the label and have 4 wide spades and 1 thin spade at the base where it plugs into the bottom of the relay box.
The symptom of this relay needing replacement is a speedometer which works but the odometer reading is no longer moving.
Would someone be kind enough to look up the part number and post it here. Thanks.
Don, what does Pelican sell this for?
Old 09-17-2008, 12:02 PM
Don, Ingo, Anyone can confirm if the relay I found is the correct one to replace? It plugs into relay position R24.
Old 09-18-2008, 04:51 AM
