Stiff clutch (already been replaced)
Back when I bought my 964/4 in January, the clutch was slipping and was very, very stiff. I replaced it right away
I was surprised when I first drove it after the replacement... the clutch was still very stiff. I use the car as my daily driver (20k miles since January), and my leg is often very tired at the end of the day, and my knee is starting to bother me. I drove an '86 Carrera the other day and the clutch was as light as a %$#@ Tercel. Surely something must be wrong... or is the 964 clutch that much stiffer? This is the one aspect of the car that detracts from it being an ideal daily driver
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats Last edited by notfarnow; 11-06-2012 at 04:59 AM.. |
Bandwidth AbUser
How's the clutch hydraulics looking, Jake? Fresh fluid? Clean slave cylinder?
Jim R. |
Thanks Jim, I guess I never considered that the hydraulics could cause it to be stiff... But I suppose it could. Maybe I should try bleeding it
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats |
I dunno- these cars have a rep for being pretty manly... Comparing it to a Tercel isn't valid IMO.
'90C4 |
I've driven other 911s with clutches as light as tercels or civics. Somethings seems to be amiss with my 964. If anything, the 964's are supposed to be "softer" 911s, better suited to daily driver usage
Science is NOT optional
Rebuild the pedal cluster, especially the pin and plastic bushings. They are cheap and help it out. Mine is pretty light.
PCA member since 1993 |
Do you know if the fork needle bearings and cross shaft were replaced? Stiff clutch is mostly caused by the rusted needle bearings seized on the cross shaft. There is also an upgrade using bronze bushings instead of needle bearings.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
This is a pretty common cause of the stiff pedal. Porsche issued a TSB for this around 1988 and Weltmeister makes a great bronze bushing kit. But, for some reason, Porsche went back to the needle bearings a few years later. When I had my tranny out three yrs. ago, I lost the left side bearing cap, so I had to get a new one. Still, next time I'm putting a bronze bushing kit in there. We did this on my '87 Carrera long ago and it made a world of difference.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Mebbe mine has an issue too!
'90C4 |
We have a 964 and '84 Carrera. Neither requires much effort. 964 might be a little easier due to hydo. Lots of other things can cause the clutch to be hard. As others have said could be peddles or other clutch related gear.
Where do you get the weltMeister bushing kit?
It was 11 yrs. ago, but I got it from our own John Walker's Workshop. Call Pelican tomorrow and see if they can get it for you. Not gonna mention competitors here, but if they can't get it, report back and I'll make some suggestions. Your local independent P-car wrench should be able to source it too.
