Even better:http://www.EZimmoblock.com - DIY install, 100 % reversible, no mods/wiring, no side affects. Lowest cost bypass available. Available on Pelican Parts, too. It's a little hard to find on their site, just search for IMMO BLOCK or IMMOBLOCK.
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo |
Unbelievable! I doubted there could be such a simple solution after all these years but gave IMMO BLOCK a try. WOW. Piece of cake to install (less than 10 minutes), even for this DIY dummy. No more fiddling with the the FOB. Does everything it claims. Pelican Parts stocks it.
Analog Air Cooled
Get a copy of the Service bulletin for 96. About 5 pages dedicated to how it works, how many random code generators it sends in every press of the fob I think 66800. The communication to the sparkplugs and the pump as well as lights, door, radio, etc. It’s really 90s humourless.
86 Targa 91 964 13 6 SPD Cayenne |
FYI - For anyone using the IMMO BLOCK defeat, there's a way you can hook it up to the car and not have to worry about changing the 9v battery. The battery lasts 2 years, but it's the type of thing you can forget, plus if the car ever changes hands, the new owner might not know the device is even installed. Instructions on how to do this : http://www.ezimmoblock.com/battery-eliminator
Immoblock. No affiliation, but he has my old zenith C2S. https://www.ezimmoblock.com/
