Engine swap question...
I was wondering if anyone knew what it would take to install an '87 930 engine into a '91 964 non turbo.
I know the oil line connections would be different and you have to accommodate the power steering pump, but what other components should one have to take into account when doing this swap? Thanks, DC |
Insert Tag Line HERE.....
you lose the PS pump, the tail, need another fuel pump and as you mentioned the oil lines, which includes the oil tank, etc. must be changed.. for starters...
easily doable though. |
Just out of curiosity, could an aftermarket electric power steering pump be installed or would the power steering rack need to be replaced with the RS America manual rack?
| Tags |
| 930 engine , 964 engine , engine swap |
