fixed wings for 993
Does anyone know of an aftermarket fixed wing for a 993 that does not require drilling visible holes in the original decklid? In otherwords, I want to be able to remove the wing in the future and put the OEM mechanized tail back in the opening and not have holes showing in the decklid?
Why not just get a fiberglass Burzel? You would unbolt the stock lid from the hinges and swap the whole panel. There would be no additional holes and the panel would look smoother and be lighter and stronger than an add-on.
any of the factory insert wings will do, RS, RS/CS, aerokit 1 or 2. I haven't mounted an aftermarket but I believe that the aftermarket copies of those wings mount the same.
here's a factory RS winghttp://forums.pelicanparts.com/uploa...1258205539.jpg http://forums.pelicanparts.com/uploa...1258205573.jpg |
These are oem RS/CS http://forums.pelicanparts.com/uploa...1258240912.jpg http://forums.pelicanparts.com/uploa...1258240963.jpg |
| All times are GMT -8. The time now is 07:04 AM. |
