fixed wings for 993
Does anyone know of an aftermarket fixed wing for a 993 that does not require drilling visible holes in the original decklid? In otherwords, I want to be able to remove the wing in the future and put the OEM mechanized tail back in the opening and not have holes showing in the decklid?
Max Sluiter
Why not just get a fiberglass Burzel? You would unbolt the stock lid from the hinges and swap the whole panel. There would be no additional holes and the panel would look smoother and be lighter and stronger than an add-on.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
any of the factory insert wings will do, RS, RS/CS, aerokit 1 or 2. I haven't mounted an aftermarket but I believe that the aftermarket copies of those wings mount the same.
here's a factory RS wing ![]()
Mammalian
1973 914 2.0 2007 Cayman |
I don't think that one will work, the rear wall is past the insert area it looks they made room for an intercooler. Oem's all just bolt to the insert area.
These are oem RS/CS ![]()
