camshafts for 964
hi help i need some camshaft advise i live in england and am having trouble getting the right cams for two engines i am building one for a road car and one for a track day car the road car is a 964 standard engine with 3.8 barrels i would like to put some hotter cams in it to make it respond a bit better i have no worries with any emmision problems so what would you advise? the other car is a track day car again a 964 block corrillo rods 3.8 nickies with a 12.5-1 comp ratio on itb,s headers and motec m48 ecu i am running a 915 box with a low ratio gear set to give me 145mph @7250rpm i have some "race cams " in it but they are a bit tame i have 300bhp all day long and it pulls well from 3000 but i want more top end power and about 25 more hp if possable can you help? i have been on the web cam site but it is ball too confusing as some people take the lift at 40thou and they take theirs at 50thou the cams i have got from ninemiester in england give their lift at zero clearence so i am totally confused please can you help thanks JEZ
for the street car SS cams are commonly used, you can't go to wild because of the Motronic intake.
for the race car i'd give Colin a call, he's got some very tasty choices for race cams
hi thanks for your reply but i have two questions what are ss cams do you mean super sprint and whats colins phone number?? cheers JEZ
yes ss cams are Supersprint, here are the specs for 4 of the cam grinds most commonly used w/ stock Motronic & stock intake
