-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   G2X owners....install question (http://forums.pelicanparts.com/showthread.php?t=568979)
Chakka71 10-10-2010 08:01 AM
Ready to install in the car. Found the wiring diagram for the 93' 964.
#16 is the rpm wire. I'm gathering i'll need to cut the casing near the plug to find the proper wire to tap into. What color(s) is the wire to just to make the wire easier to find? The plug list I have only says what it they go to, not the color.
Where is the best place to get my "key on" power and ground? I read the brown/red is key on power for the radio and brown is ground. Are these locations/hookup ideas okay to go with? Is there a better/easier choice?
Thanks!
Bill Verburg 10-11-2010 09:51 AM
Thanks!
I'd pick up the tach signal at the back of the tach, black/purple wire
Chakka71 10-11-2010 03:21 PM
Looked from underneath but no luck seeing it. Not sure how to get to it.......i'm sure it's easy, but haven't had a reason(knock on wood) to hunt around. Figured it's better to ask from those that are experienced!
Bill Verburg 10-11-2010 03:29 PM
pull the tach
Chakka71 10-11-2010 04:51 PM
Looking at the wiring diagram, went to the OBD connector and checked the plug for RPM (pin#14) then tapped it from behind the plug. Perfect!
