Chakka71's Avatar
G2X owners....install question
Ready to install in the car. Found the wiring diagram for the 93' 964.
#16 is the rpm wire. I'm gathering i'll need to cut the casing near the plug to find the proper wire to tap into. What color(s) is the wire to just to make the wire easier to find? The plug list I have only says what it they go to, not the color.
Where is the best place to get my "key on" power and ground? I read the brown/red is key on power for the radio and brown is ground. Are these locations/hookup ideas okay to go with? Is there a better/easier choice?
Thanks!
PCA National Instructor
93 RS America (some things done to it....)(gone)
85 Carrera (gone)
06 BMW M5 (gone)
"If you ain't first, your last"
Old 10-10-2010, 08:01 AM
Bill Verburg's Avatar
Thanks!
I'd pick up the tach signal at the back of the tach, black/purple wire
Bill Verburg
Old 10-11-2010, 09:51 AM
Chakka71's Avatar
Looked from underneath but no luck seeing it. Not sure how to get to it.......i'm sure it's easy, but haven't had a reason(knock on wood) to hunt around. Figured it's better to ask from those that are experienced!
85 Carrera (gone)
06 BMW M5 (gone)
Old 10-11-2010, 03:21 PM
pull the tach
Bill Verburg
Old 10-11-2010, 03:29 PM
Chakka71's Avatar
Looking at the wiring diagram, went to the OBD connector and checked the plug for RPM (pin#14) then tapped it from behind the plug. Perfect!
85 Carrera (gone)
06 BMW M5 (gone)
Old 10-11-2010, 04:51 PM
