Garbageman
G7miami's Avatar
Send a message via AIM to G7miami
964 Backdate Project
I just got this car from California as a new project. 1990 Carrera 2 with G50 and some backdates. The car was gone through for a Pre Purchase Inspection by John Chambers in Oceanside, CA and he documented that the car had suspension issues and #5 cylinder had 0 lbs pressure on the leak down test and seemed to have a exhaust valve sticking.
I bought it off the internet and had it shipped to Tallahassee for fit and finish issues at G. Davis Auto, a trusted Porsche Mechanic and my brother.
Greg the Garbageman
Old 01-23-2011, 09:07 PM
Garbageman
G7miami's Avatar
Things I Liked
The car was overall clean, had the rear seat delete, good base colors, clean car-fax, and upgraded suspension to Bilstein & H&R green springs.
Work had been done to make it a 73 RS clone and the front quarters had been extended, they had made it a long nose, R Gruppe light in the rear, RS door panels, they put the duck tail on and the Carrera logos.
Greg the Garbageman
Old 01-23-2011, 09:16 PM
Garbageman
G7miami's Avatar
Things I Did Not Like
I knew immediately the green colors had to go, so I was ready for some changes immediately. I also needed to fix the front suspension issues and #5 cylinder. There were fit, finish and interior issues that I would be getting on.
Greg the Garbageman
Old 01-24-2011, 09:06 PM
yep, im slow in the head
carslutt's Avatar
Send a message via Yahoo to carslutt
looks like a good start for an project
1978 911sc Targa - CNC plasma/router cut parts, tig welding, sheet metal work, VAG-COM, LM-1. let me know if u need something
Old 01-25-2011, 10:18 AM
SAM DACOSTA's Avatar
Keep us posted with pictures and updates as you work your way thought the car. I think you've started with a good base car and it can only get better from there.
SAM DACOSTA
1990 Porsche 911 Cabriolet (964)
2000 Porsche Boxster (986)
2002 Porsche 911 C4S (996)
Old 01-25-2011, 01:56 PM
Garbageman
G7miami's Avatar
Let's get Started
Once the car was delivered to G. Davis Auto in Tallahassee, we got a better look at the car
We decided the car needed new rubber, springs, wheels stripped and repainted.
Greg the Garbageman
Old 01-25-2011, 02:46 PM
Garbageman
G7miami's Avatar
Things We Ordered - To Start
Tire Rack
(2) 205/50ZR -17 Continental ExtremeContact DW XL
(2) 255/40ZR -17 Continental ExtremeContact DW
(1) H&R sport-spring (red) #29834
(1) Bilstein hd strut fl 35-052777
(1) Bilstein hd strut fr 35-052784
Greg the Garbageman
Old 01-25-2011, 03:01 PM
Garbageman
G7miami's Avatar
Getting Started
We got the car in the air and removed wheels for color change and decided to drop the motor out to rebuild the top end.
Parts Need to be Cleaned
Looking Clean and Pretty - Now the heads were sent to Anchor Atlantic for attention
and the parts were stored on the shelf.
Wheels and Springs arrived.
Rear view with motor out and new springs installed. We realized once we took the front springs off that the prior owner had stripped the heads on the Bilstein shocks and we needed to replace them.
Wheels were stripped of green color and prepped for respray, because of cold weather they were left to dry in a heated room for two days.
Greg the Garbageman
Old 01-26-2011, 07:18 AM
Garbageman
G7miami's Avatar
Little Details
Since the colors are white and black, Geoff sent me to Ernie's Alloys to get a set of old center caps and use them to accent the car. Great Idea.
Tires Mounted
Greg the Garbageman
Old 01-26-2011, 12:00 PM
Garbageman
G7miami's Avatar
The Wait
Waiting on more parts
Greg the Garbageman
Old 01-31-2011, 11:34 AM
Garbageman
G7miami's Avatar
Parts In - Rebuilt Starting Point
Anchor Atlantic and Pelican Parts supplied all the items I needed to get this project back on
track
Greg the Garbageman
Old 02-06-2011, 11:28 AM
Garbageman
G7miami's Avatar
New B&B Headers & Exhaust - but I get stuck
So I just got a B&B Exhaust off Pelican (thanks Matt) and my mechanic/builder/brother has an emergency for his biggest client, so I am stuck for about 30 days.
Greg the Garbageman
Old 02-10-2011, 09:33 PM
Schwarzeritter's Avatar
Location: PaloAlto Calif, IndianWells PalmDesert, Japan
Cool project.
Taze em..TAZE EM ALL!!
A man that builds a thousend bridges is a bridge builder, but a man that sucks one ( blank ) is a ( blank ) sucker.
It looks like the 4th of July from my rear view, how about from your view?
Old 02-10-2011, 11:08 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
very cool. ive thought about doinjg a 964 backdate myself.
BUT, whats with all the 911 rollers in the background picture?????
Old 02-11-2011, 11:51 AM
Don Plumley's Avatar
Nice - looking forward to seeing this.
Don Plumley
M235i
Old 02-12-2011, 08:01 AM
Garbageman
G7miami's Avatar
Got a few more Porsche projects waiting on funding. Damn Economy and expensive children keep the projects to 1 a year. Last years 69 Firebird 400 RestoMod took almost 1200 hours. Keep watching for the 964 backdated to 74 IROC RSR after I finish this one.
Greg the Garbageman
Old 02-13-2011, 09:13 PM
Send a message via AIM to Mike Hall
Is G. David Auto the little porsche shop down in Tally? I have been trying to find the place I went to years ago to see if they have any projects or at least some parts I might could use on a 66 912 I just bought.
Mike
Old 02-17-2011, 08:53 AM
Garbageman
G7miami's Avatar
Getting back to Work
So after a little distraction called work, we are back into the project. As always we decided to go a little deeper into the rebuild, and cracked the bottom end to get a peak.
Case Opened
Case Closed
Greg the Garbageman
Old 02-26-2011, 10:12 AM
Garbageman
G7miami's Avatar
Coming Along
Greg the Garbageman
Old 05-25-2011, 06:16 PM
Garbageman
G7miami's Avatar
Gosh Darn It - When can I drive It
So it is close, but no cigars, worse yet it is 500 miles away so I can even pop in and give it a test drive.
But here are some pictures, just waiting on more PARTS
Need to do a little more figuring on this part
Greg the Garbageman
Old 06-22-2011, 08:48 PM
