welding precautions, reapplying coatings
Hello- I am getting ready to weld on a front jacking point to a 964. Since the car is full of electrical and electronic gizmos, what precautions to remove or disconnect these is appropiate? Second question-after welding, what coatings should be reapplied to the area that was hot? Thanks
Old 03-12-2011, 02:33 PM
Now in 993 land ...
aigel's Avatar
Not sure why you'd need to weld a jacking point on a 964? That said, what I would do is disconnect the battery and keep the ground clamp of your welder in very close proximity of your welding locatoin. That will leave practically no current to flow through the rest of the car.
Hope this helps,
G
81 SC (sold)
Old 03-12-2011, 09:51 PM
Because they get distorted from careless jacking, tow truck operators, etc.
Andreas
1995 993 Coupe, Polar Silver / Black
2014 Audi A4, Monsoon Gray / Black
2002 Toyota 4Runner, Dorado Gold
2001 Toyota 4Runner, Dorado Gold, 604,XXX 1-owner miles
1998 Toyota 4Runner, Oxidized, 5-speed
Old 03-13-2011, 08:32 AM
Alps Adventurer
Traveller's Avatar
Clean the area very well.
Use a quality zinc primer, paint and apply that coating they use in the wheel wells. Let each cure between applications.
All the best,
Alex
1995 Carrera 2 - Speed Yellow - Alps Touring
Old 03-13-2011, 09:05 AM
Thank you for your answers- I will plan to use Wurth Alu Zinc primer and Underbody Seal over the area after welding.
Old 03-14-2011, 04:07 PM
