-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   OBC tach swap? (http://forums.pelicanparts.com/showthread.php?t=596845)
Mike Hall 03-14-2011 09:22 AM
OBC tach swap?
What are the chances a OBC tach can be swapped in a car that has a non OBC tach? My tach has some pant chipping on the face and I was thinking why not just upgrade to a OBC tach. I know there must be some wiring missing to run the OBC but maybe not?
Mike
milutintin 03-14-2011 11:40 AM
If it is a 964 you have all the wiring. The only one left is the exterior temperature sensor.
Mike Hall 03-14-2011 02:07 PM
I have a 92 964 so all the wiring that is needed is for the exterior temperature sensor? If that is the case, updating to the OBC will be easy.
thanks
Mike
