993 will not start
I have a problem with my car (95 993) in that it's not starting. The problem occur after I washed the car's engine. I'm not getting any fuel or electrical signal. I've checked the fuel pump and it's working. What could be the problem? Thanks for your help.
Insert Tag Line HERE.....
is it turning over at all?
Yes the car is cranking but not starting. I've bought a coil but that's not it. Today I removed the electrical connectors and applied compressed air still not starting. I've borrow a DME relay from a friend car and nothing happens. The relay works the fuel pump- I've bridge the connectors- but it's not starting.. Would you please outlined the steps to take. Thanks.
gassssssss
did you ck the fuses?
All of the fuses under the hood were fine as well as the three in the engine bay
This is a crazy question but do you still have power to the dome lights?
86' 951 k26/27 hybrid turbo 01' audi s4 98' TDI jetta 96' 933tt AWD LS1 |
993 will not start
yes I have power at the dome lights? What does that has to do with not starting?
Your post caught my attention because the same thing happened with my 96' 993 friday night. I washed it and it wouldn't start. My car has an LS1 in it but I connected my LS1 ECM to the stock ECM wires and I'm using the stock fuel pump, fuel pump relay and fuse position. After I washed it it started then died on the way back into my shop. The motor would turn but no fuel pump or ignition. I jumped the fuel pump relay and still no start. I started looking for other things that didn't work and noticed that the dome lights weren't working. I checked fuses and relays and after a few minutes everything came back. Fuel pump, dome lights.. motor fired up and ran fine.
gassssssss
sounds more like a land rover issue.....
ah ah ah Hope you get it fixed |
993 not starting
I've never had such a BIG little problem before!! Still can't get the car to start. I've replaced the relay, replaced the coil, blown out every connector on the engine all to no avail!!! All this because I washed the engine.
Any help?? Last edited by vdog; 09-21-2011 at 03:15 PM.. |
Did you remove the distrubutor caps and check for moisture inside?
Yes, I did that and I replaced the coil and the DME relay, this started after I washed the engine
What should I do next... any ideas, anyone?
I'm thinking that my problem was a fuse or relay connection in the box. Even though the fuses are good, I'm thinking one of mine wasn't passing current. Try removing each fuse, or at least the ones related to the ecm/fuel pump/ dme and check for corrossion. Maybe apply some dielectric grease as well. I don't think you have a big problem. just a connection issue.
I'll check it out tomorrow. If that doesn't get it I'm taking it to Doc's a Porsche repair shop.
any news vdog?
Somatic Negative Optimist
With my first 911 years ago, washing resulted in a no-start and then a shaky start.
Since then, I use a heavy-duty plasic sheet under the lid to cover the engine before washing. To prevent accidental starting with the plastic over the engine, ignition key is under the floor mat. Works great on the 911 and now the 993. I suggest re-checking the fuses and make sure that the DME relay really works.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Alps Adventurer
Actually confirm whether or not you are getting spark and whether or not you have the correct fuel pressure.
Are your injectors getting a signal? Thats just a start. |
