993 C4S Electrical problem. Where to start?
I have a 97' 993 C4S with a new electrical problem. I have owned car for 4 years with no previous problems of any type. I noticed first that the stereo( radio or cd) would lose power when driving(usually when shifting)for a second and then regain power. Now when I shut the car off and lock it with my key fob and then try to unlock with the fob I hear a weak click at the door lock (the vacuum? lock does not unlock). When I unlock with the manual key and then try to turn engine on it is as if I have a very weak battery(dash lights weak) and engine won't turn over at all. After a random number of tries turning ignition on and off all of a sudden dash lights are normal brightness and car starts normally. I have replaced the battery and checked the battery terminals. I assume I must have a loose wire somewhere. Any ideas of where to start looking? I didn't know if this could be a fuse problem. Thanks in advance for any suggestions.
good luck. Craig
2012 Cayman R Chartreuse / 3 pedals 2009 2S Nordic Gold over Cocoa, my sweeties car (Chairman Meow) 2024 Audi A4 Allroad Navarra Blue over Grey 2010 Audi A6 Avant Grey over Grey - Supercharged! Lottsa "steel is real" bicycles |
I second the ground strap. Even more, replace. May be connected good, but I have been told that even if it looks good, over time it will build up resistance. As soon as I changed mine my weird dash lights and other problems stopped. The strap I replaced looked almost new!
Neal |
Alps Adventurer
All he has to do is turn on all high current devices (high beams, rear window defroster, cabin fan on high, etc) and measure the voltage drop across the battery ground cable. It should be in the millivolts at the most. |
