993 engine fan
My 1996 993 seems to do some weird stuff - the cooling fan for the heat exchanger turns on long after I park the car. Is the sensor bad? No codes or engine lite on. Thx
could be many things mine will if it is hot and the car sits a for a while and I turn the key back on to start the car it will vary its speed though.
though I believe that is controled by the ccu plus the temp sensor
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
You could have a sticky fan relay, a common enough issue. Rap on it with a screwdriver handle while the fan is on after shutting down. If it is sticking, the impact will probably release the relay.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
When you park the car, the temperature rises in the engine compartment. The temperature sensor could trigger the fan long after you shut the engine off. |
