Manassas, VA
lucittm's Avatar
Look What I Did To My Headlights
I am happy with the 9004 replaceable bulb headlights in my car. According to my research, Porsche used a sealed-beam unit (designated the H5) for 1986-1989 USA cars because the H4 was not approved for use in the USA (until 1992). Due to owner's dissatisfaction with the performance and cost of replacement of the H5, they converted to the 9004/HB1 replaceable lamp in a modified RoW reflector in 1990. Please correct me if I'm wrong here, most of the information came from the PEC.
In any case, the combination of replaceable bulb and plastic reflector create a film on the inside of the glass lens that gives a smokey/silver appearance. I found a way to clean the inside of the lens. I removed the headlamp from the car as a unit. I took off the bulb and the humidity absorbent. Then I poured in about half a cup of clean kitty litter. I shook the headlight back and forth for about 5-6 minutes and dumped out the kitty litter. It took awhile to get it all out.
Here is the result:
I hope someone else finds this useful.
Thanks,
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 12-22-2008, 08:01 AM
930gt-40r's Avatar
That is an awsome fix... I will have to try that when I come accross that problem on one of my customer cars.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 12-22-2008, 08:09 AM
965 965 is offline
Mark,
I cleaned one of ours using Windex. However, it clouded up again a few days later. The second time I took it out, I filled it with water and discovered a leaky seal where the reflector is bonded to the lense. I sealed it with RTV and cleaned it again and dryed it thoroughly. It has stayed clear for a few months now.
I'll give your method a go if I have to clean one of them again.
Old 12-22-2008, 03:50 PM
Don Plumley's Avatar
I've done the same with rubbing alcohol - really shined stuff up. But you'd want to be careful with solvents as it might eat the reflector. Kitty litter is interesting, don't have any around - but be careful not to scratch the reflector.
Don Plumley
M235i
Old 12-22-2008, 08:40 PM
rsrmike's Avatar
De-natured alchohol will do the very same thing, just swish it around a few seconds and pour it out... I think there is a service bullentin mentioning the denatured approach ...
Professional Overcomplicator
Old 01-03-2009, 09:01 AM
Manassas, VA
lucittm's Avatar
Mike,
Now you tell me... But I had fun with the kitty litter.
Mark
Old 01-03-2009, 09:53 AM
rsrmike's Avatar
LOL Sorry Man, I started a new job and have been pretty busy!
Sounds like fun though
Old 01-03-2009, 11:08 AM
group911@aol.co's Avatar
Kitty litter is the same thing as floor dry. Maybe the liquids first followed with the litter/ dry would be good.
Thanks,
Bob
group911@aol.com
Old 01-03-2009, 04:49 PM
Metal Guru
911nut's Avatar
I tried acetone, a sponge and a long screwdriver. Improved it somewhat but it still quite doesn't match the new one on the other side.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 01-06-2009, 02:03 PM
colo964's Avatar
I used Everclear and thought that I was a backwoods genius. Good to know there are other tricks.
Old 01-07-2009, 01:32 PM
Manassas, VA
lucittm's Avatar
Everclear? That is alcohol abuse. You are abusing the alcohol. If I had some Everclear, I would mix it with OJ and then not worry about my headlamps.
Mark
Old 01-09-2009, 06:15 AM
colo964's Avatar
You can reuse the Everclear with the road salt in it, throw in a few olives or onions and have a dirty Ozark martini or gibson.
Old 01-09-2009, 10:03 AM
Merge these concepts for a solution that worked well for me (before I installed H4's in order to have lights that actually do the job) by adding a few spoons of uncooked rice to the alcohol and swishing it around on the inside of the glass. It removes the film without the risk of scratching the innards. Like the litter, you have to fuss with it a while to get all the rice out, then use a hair drier or leave it overnight before reassembling.
Old 01-10-2009, 08:26 PM
OK. Here's the official cleaning kit from Riedel wine decanters on cleaning them. Basically, a bunch of bb's in water. Sorry about the pic.
Thanks,
Bob
group911@aol.com
Old 01-11-2009, 10:16 AM
Manassas, VA
lucittm's Avatar
Who knew? A corporate solution to our problem. Well done!
Mark
Old 01-12-2009, 06:16 AM
SouthCoastPhil's Avatar
I used some bottle brushes with the rubbing alcohol, since they have a soft tip already attached to a handle, and one can bend the handle:
I've also seen these online. Might consider cutting the bristles off the sides?
A search for "Bottle Brushes" turns up many sources.
88 Venetian Blue Coupe "B"--gone, but not forgotten
93 964 C2 Coupe "BNC" ("PNC" on some days!)--PSS9s, Big Reds, Strut Brace, Recaro SRDs, Schroth 5-pts, DAS bar
Old 05-21-2012, 05:33 AM
964TargaC2's Avatar
Hydrogen peroxide also works well
Old 05-21-2012, 09:57 AM
Yup...Thanks,964TargaC2!
My original post can be viewed here:
http://forums.pelicanparts.com/porsche-964-993-technical-forum/678252-foggy-inner-lamp-lens-90-964-c4.html
Best Regards,
Tony
90-964-cab
Old 05-21-2012, 12:24 PM
efhughes3's Avatar
Rice and alcohol have been used by many, and would be safer than kitty litter.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 05-21-2012, 06:23 PM
