Stian911's Avatar
Leak power steering unit
Just found power steering liquid around the battery. Looks like it's comming from the power steering unit. Anyone who has experienced the same problem? Any tips and hint on what to do?
Old 06-25-2012, 12:20 PM
Hi,
that photo has nothing power steering related in it. What you've pictured is the hydraulic pump associated with brakes and the diff actuators (if you have a C4).
Looks like possibly you have a leak around the lovely green component shown, which is the hydraulic system pressure switch. Check PET to see if there's a seal; if you decide to change it make sure you bleed the pressure off first; probably it'll make a right mess if you don't.
HTH,
PTD
'90C4
Old 06-25-2012, 08:59 PM
