911buff
911buff's Avatar
964 engine/transmission woes
Just replaced the starter and now the transmission will not shift on its own or go into manual mode. Did I disconnect the harness to the transmission? Then just before I got it to the house, the engine began to cut out and then cut back in...rinse/repeat the rest of the way home. When I got home and shut off the car, a rather large cloud of smoke emerged from the engine bay. It sort of smelled electrical. Anyone have any experience with these symptoms? Thanks!
Old 12-21-2012, 05:17 PM
rs27carrera's Avatar
If you did nothing but replaced starter, are yuo sure "new" one is working and not having continuous shortcut and this causing trouble and smoke. Did battery cable give any sparks when you receonnected it?
Even new started worked initially, it may have failed as well - was it brand new?
Kind regards, Harri
964 C4 1992, 930 "RS3.0 looker", Carrera 3.0 1976
911 2.4E 1972 (to be 2.4S+ spec race car), 911 2.2T 1967
Old 12-21-2012, 05:33 PM
Oleg Perelet
That's end of the world thing, happens once in awhile.
Oleg.
Old 12-21-2012, 07:21 PM
911buff
911buff's Avatar
Well, I found the culprit...it was me. I did not connect the grounding strap to the lower starter bolt, so all kinds of electrical problems were inevitable. Connected the grounding strap and all is well! I will pay closer attention next time!
Old 12-22-2012, 02:43 PM
Happy new year!
'90C4
Old 12-28-2012, 01:13 PM
