Don Haney's Avatar
Tiptronic Trans Service
My fairly new to me 91 C2 is a Tiptronic. Has anyone completed this service ?
The service manual isn't very clear on filling. Draining and filter replacement looks like a no brainer.
Is there a side fill, or only through the "quick fill" The manual refers to a Special tool but doesn't list the tool. I have called Porsche and they can not find the tool info other than it is a VAG #, my dealer contact even spoke to the techs and they don't know. Hope someone has this info. Would like to service the trans.
thanks for your help,
Don
91 C2
Don Haney
don@pelicanparts.com
888-280-7799 Ext 305
1991 C2 Tip - Sold
Old 06-27-2002, 08:03 PM
Don, you don't need the "quickfill" device.
Remove the bolt that holds it onto the trans and pump the fluid in that way. ALWAYS replace the crush washers and don't overtighten the bolt.
Note that early Tips have incorrectly marked sight guages, fill the trans to about 5mm above "max' when hot (after driving for at least 20 minutes. There is a technical bulletin for this that gives you the exact preceedure.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 07-01-2002, 05:47 PM
