-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=32)
-   -   Clacking noises on the engine passenger side (http://forums.pelicanparts.com/showthread.php?t=737002)
bazar01 03-03-2013 07:22 AM
I noticed this morning when I drove for about 30 minutes. The noise was there even when cold and also when warmed up. It is quite loud.
I m going to put it on the li ft, drain the oil and open the pass side valve cover and peek inside the cam box.
Last valve adjust was 30k miles ago.
I've heard about rocker shaft walking and lash adjusters maybe.
Anything else to check?
Jim Richards 03-03-2013 07:33 AM
Maybe. Or a failed chain tensioner? I wouldn't keep running the engine with that noise.
Jim Richards 03-03-2013 10:06 AM
One more thought, does it make any noise when the engine is running while you car is standing still?
bazar01 03-03-2013 10:12 AM
Yes, even while idling, there is a loud clacking noise. I'll see if I can record a sound clip.
I was thinking a loose lash adjuster jam nut.
bazar01 03-07-2013 04:11 PM
I went ahead and open the passenger side valve covers. All the rocker arm valve adjusters and lock nuts are all tight.
Even the head stud barrel nuts are in tact and nothing fell off.
I will go ahead and do a valve clearance check and adjust if necessary.
Anything else I should check that is the likely cause of the clacking noises?
Jeff Burger 03-07-2013 06:00 PM
hows your power steering fluid level ?
bazar01 03-08-2013 02:47 AM
I have not checked it. Thanks Jeff.
efhughes3 03-09-2013 08:12 AM
30k since last valve adjust? I don't know the 964 specs, that seems awfully long ago.
Short of any glaring issue, that would have been the first thing TO do, IMO. Then, if noise persists, post for help.
bazar01 03-09-2013 05:20 PM
I know, it's long overdue, so I went ahead and did the valve clearance check. Cylinder #4 exhaust is too loose and intake too tight. I put it to spec at 0.004" traditional method.
All head studs still intact. No broken studs or falling off nuts.
st
I will go ahead and change the spaark plugs and change the oil.
If noise persists, I will open the chain box.
A few pics.
Spark plugs 123 upper
http://forums.pelicanparts.com/uploa...1362878241.jpg
Rockers 123
http://forums.pelicanparts.com/uploa...1362878289.jpg
Spark plugs 456 upper
http://forums.pelicanparts.com/uploa...1362878349.jpg
Rockers 456
http://forums.pelicanparts.com/uploa...1362878381.jpg
bazar01 03-09-2013 05:55 PM
How can the chain tensioner fail?
I did not see anything unusual in the camtower/rocker area that was loose.
Bubbling well 03-09-2013 09:32 PM
how old is your power steering belt? maybe stretched and banging inside?
bazar01 03-10-2013 03:46 AM
I changed it at about 30k miles when I addressed the pump cam shaft drive housing o-ring and seals oil leaks.
But I can check the power steering belt and pulleys while the car is on the lift.
Thanks.
bazar01 03-10-2013 04:23 AM
Do you know what can fail in the right side chain box that can clack?
http://forums.pelicanparts.com/uploa...1362914512.jpg
bazar01 03-10-2013 02:59 PM
Put everything back together with new plugs, valve adjusted and fresh oil. Clacking is gone.
Thank goodness it was nothing major. I don;t have to open the chain boxes for a failed tensioner.
