Clacking noises on the engine passenger side
I noticed this morning when I drove for about 30 minutes. The noise was there even when cold and also when warmed up. It is quite loud.
I m going to put it on the li ft, drain the oil and open the pass side valve cover and peek inside the cam box.
Last valve adjust was 30k miles ago.
I've heard about rocker shaft walking and lash adjusters maybe.
Anything else to check?
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 03-03-2013, 07:22 AM
Bandwidth AbUser
Jim Richards's Avatar
Maybe. Or a failed chain tensioner? I wouldn't keep running the engine with that noise.
Jim R.
Old 03-03-2013, 07:33 AM
Bandwidth AbUser
One more thought, does it make any noise when the engine is running while you car is standing still?
Jim R.
Old 03-03-2013, 10:06 AM
Yes, even while idling, there is a loud clacking noise. I'll see if I can record a sound clip.
I was thinking a loose lash adjuster jam nut.
Old 03-03-2013, 10:12 AM
I went ahead and open the passenger side valve covers. All the rocker arm valve adjusters and lock nuts are all tight.
Even the head stud barrel nuts are in tact and nothing fell off.
I will go ahead and do a valve clearance check and adjust if necessary.
Anything else I should check that is the likely cause of the clacking noises?
Old 03-07-2013, 04:11 PM
ahead of the curve
Jeff Burger's Avatar
hows your power steering fluid level ?
19 Carrera T - MPS member
92 C2 SR coupe M491/ 3.8 look- manual
92 C2 SR coupe cobolt blue- manual
73 914 1.7 (?) AG -a solid project looking 4 a sugar daddy
73.5 T gemini blue SR coupe sold 8/22 my last long hood gone
Old 03-07-2013, 06:00 PM
I have not checked it. Thanks Jeff.
Old 03-08-2013, 02:47 AM
efhughes3's Avatar
30k since last valve adjust? I don't know the 964 specs, that seems awfully long ago.
Short of any glaring issue, that would have been the first thing TO do, IMO. Then, if noise persists, post for help.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 03-09-2013, 08:12 AM
I know, it's long overdue, so I went ahead and did the valve clearance check. Cylinder #4 exhaust is too loose and intake too tight. I put it to spec at 0.004" traditional method.
All head studs still intact. No broken studs or falling off nuts.
st
I will go ahead and change the spaark plugs and change the oil.
If noise persists, I will open the chain box.
A few pics.
Spark plugs 123 upper
Rockers 123
Spark plugs 456 upper
Rockers 456
Old 03-09-2013, 05:20 PM
How can the chain tensioner fail?
I did not see anything unusual in the camtower/rocker area that was loose.
Old 03-09-2013, 05:55 PM
Bubbling well's Avatar
how old is your power steering belt? maybe stretched and banging inside?
Old 03-09-2013, 09:32 PM
I changed it at about 30k miles when I addressed the pump cam shaft drive housing o-ring and seals oil leaks.
But I can check the power steering belt and pulleys while the car is on the lift.
Thanks.
Old 03-10-2013, 03:46 AM
Do you know what can fail in the right side chain box that can clack?
Old 03-10-2013, 04:23 AM
Put everything back together with new plugs, valve adjusted and fresh oil. Clacking is gone.
Thank goodness it was nothing major. I don;t have to open the chain boxes for a failed tensioner.
Old 03-10-2013, 02:59 PM
