Location: behind the redwood curtain, (humboldt county) california
Fuel line in a bad place
When I first pulled Dad's 74 into the driveway, I smelled gas. I jacked it up to find what looked like an original fuel line, right under the heat exchanger hot air dump.
It is amazing that it lasted as long as it did.
Replaced it with some napa fuel injection rated hose and installed some stratoflex heat shielding, (supposedly good enough to protect a fuel line laying on an exhaust manifold.
This last shot was The Big Clean up after the block thermostat popped out and oiled everything. The pump was subsequently relocated to the front of the car.
Old 12-28-2013, 08:35 AM
The new lines I used came off my wrecked car. So they were pre-formed. They would have to be pre formed because of the journey they take. Its a long one.
Old 12-28-2013, 09:29 AM
Greg, nice work doing it on jack stands. Any tips or pics you can share? TIA.
1996 MIDNIGHT Blue Grey 993 Carrera
Old 12-28-2013, 09:45 AM
Here's a post I found perhaps with some other alternatives and resources. I too am seriously thinking about refurbishing my fuel lines..
Dan
http://forums.pelicanparts.com/porsche-911-technical-forum/80621-notorious-carrera-3-2l-rear-fuel-line-leak-revisited-long.html
Old 12-29-2013, 09:47 AM
