1991 911 c4 brake bleed
Hi I have a 1991 911 c4 this car has been in storage for 8 years the dashboard trac control and brake lites were on when we started the car. I replaced the pads and rotors - power bled the system- lite still on. I see the integrated hyd. systems and believe I have not properly bled the brake/ trac. system. Is there a manual describing the procedure for bleeding the entire system? or can someone provide me with the factory procedure? thanks Scott
Old 07-05-2013, 07:44 AM
There is a more active 964 community at Rennlist; a search over there will turn up what you need.
Make sure the fluid res is up to Max while the car is running; this is a common cause of warning lights.
'90C4
Old 07-05-2013, 11:07 AM
C4: Brake bleed / hydraulic system bleed procedure - Rennlist Discussion Forums
Old 07-07-2013, 06:28 AM
