Need to identify a part
Hi,
On my 91 C4 I found the following tube.... I have no idea what the purpose is - any clues? Itīs only ziptied for maintenance purposes. Thanks. SAM ![]()
Just Air! |
Fleabit peanut monkey
I see nothing that indicates it comes from the filler neck.
![]() Throw us a bone and show us where it connects on each end. :-)
1981 911SC Targa |
Hi,
No itīs not involved in the fuel filler assembly...
Itīs comes out of the Sidewall.... It has a open end - and the other End is hidden behind my vision ![]() Thats the reason i ask if anybody knows ![]() Thanks. SAM ![]()
Just Air! |
Seems...
It seems like itīs a overflow/ ventilation hose - following this pic...
Suggestions? Thanks. SAM ![]()
Just Air! |
Alps Adventurer
Brake fluid reservoir overflow.
Slip the rubber hose off at the reservoir and blow air through it. |
Cool...
Thanks!
Interesting Info. SAM ![]() http://forums.rennlist.com/rennforums/attachments/964-forum/594594d1325188894-c4-brake-bleed-hydraulic-system-bleed-procedure-brake_cap_hinweis.pdf
Just Air! |
