fasterlaster's Avatar
Shifter adjustment in c4
My new 964 has a strange behavior for shifting. When I move from its resting place in the 3/4 plane it does not like to go into the 1/2 plane unless I pull back on the shifter about half an inch. I haven't taken a closer look yet, just looking for suggestions.
Sent from my Nexus 5 using Tapatalk
1974 Porsche 911 Targa w/ 3.2L
1989 Porsche 964 Carrera 4
Old 05-12-2014, 02:04 PM
I'm not sure how much that made sense so I made a video
Porsche 964 shifter - YouTube
Old 05-12-2014, 03:03 PM
Here is a reading material on the shifter adjustment. See if this helps. If not, then you need to investigate the shift coupler inside the tunnel behind the front seats. There is an access to see the coupler.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 05-13-2014, 08:26 AM
Yes,I saw this page also. Not exactly the best description of how to adjust. I did determine that my engine mounts are shot, so I'm changing those first. Thanks
Old 05-17-2014, 04:13 PM
My 993 shifter was sloppy and difficult to get into reverse. I put in a short shift kit and shift rod. Along with motor mounts. Best $ I spent yet concerning shifting.
Old 05-17-2014, 06:02 PM
