Håkon Arne
Bolt on clubsport flares 993, what kind of bolt...
What kind of bolt is this, and where do i get them? Or should i use another type...
What was original used?
Front & Rear Linnsenschraube(oval head screw) M5x16 x16, M5x20 x4 Unterlagscheibe(washer) 9.5x5.1x0.5 x22, Stop-Mutter(nut) M5 x22
Banned
Bill are these available thru Porsche with a part number or just local hardware store supply?
We need to give Bill the new name of "The 993 Librarian" as he can always be counted on to answer such question here and on rennlist. He is a credit to the forums. :cheers:
M5x16 900.623.001.00 M5x20 900.623.002.00 washer 993.504.515.80 M5 nut 900.380.001.02 gasket white 993.504.333.80 gasket black 993.504.331.80 As I mentioned above the '96 versions used 10 more fasteners than the '97
Banned
bill is this (gasket black 993.504.331.80) the gasket that goes inbetween the rear flair and body quarterpanel ?
yes, it comes in a roll to do the 4 fender flares
Håkon Arne
Many thanks Bill!
Wheel Flares
For what it is worth, the fasteners are also called "button heads". They can be purchased at most Ace Hardware Stores and from Metric Multi Standards. They are great to deal with. They Carrie almost every type of fastener in stainless and are in most large metro areas. One line they carry is made in Germany and very high quality. You have to be careful of junk from China
1987 911 Coupe Triumph Trident Track Master History is the lie we all agree to.......... |
