Send a message via ICQ to Alan Herod
Ignition Switch Return Spring
I have searched the archive and have not found the answer...
It seems the spring in the ignition switch has failed. When released from the 'start' position the switch does not return to the 'run' position. Where is the return spring located, it does not seem to be located in the electrical subassembly; but, in the mechanical portion.
If it is in the mechanical portion the replacement ignition switch is about $965. Can the mechanical portion be repaired?
Alan
83 SC
90 964 C2
08 135I; 13 Audi S4
02 Boxster S (destroyed); 57 Carrera Speedster (escaped)
Old 03-11-2015, 10:53 AM
What car?
Old 03-11-2015, 11:02 AM
It is a 1990 964 C2.
Alan
83 SC
90 964 C2
08 135I; 13 Audi S4
Old 03-11-2015, 11:05 AM
I had a problem with the ignition switch in my 993 (993 and 964 switch are the same) and after doing some reading, I came away with the impression that it is the electrical portion of the switch that contains the spring function. My impression may be wrong as it turned out my problem was related to the key rather than the switch, so I was spared the pain of pursuing the switch issue. The good news is that the electrical component is the cheaper component to replace (Approximately $115 from out host). The bad news is that getting to it is a PITA.
Old 03-11-2015, 11:38 AM
