Need help on brake issue - 964 Carrera 2
Hi all,
I recently disassemble the four brake calipers to paint, as well as the ABS pump on the front trunk in order to clean the area. Today I have been assembling all the parts. After bleeding the calipers through the typical method (pumping the pedal to make the air out - no pressure machine was used) something strange happens: After I bleed the four calipers the pedal feels fine with the normal hardness. After I start the car, the pedal goes down and I have to pump it two times to have it hard again. Does anyone knows what did I do wrong ? I have been using this method to bleed many G series cars and it always works... Does it has to do with the fact of disassembling the ABS pump? Thanks in advance for any help.
K-Jetronic student
I think it's related to the ABS which the G series cars don't have. I have had good luck using the Motive bleeder with my 964. Have to block the vent hose, though.
1990 964 Coupe 1986 Carrera 3.2 Targa |
Thanks for your reply. Do you know if it is possible to bleed the ABS pump alone?
K-Jetronic student
I always use a pressure bleeder on ABS cars
you have air in the ABS pump the air can't be easily removed w/o cycling the pump, You will need a hammer or Piwis to do so. w/o a Hammer or Piwis the only other option is to try to lock, thus cycle) the brakes in use, hopefully on a closed road.
It could very well be possible that the seals in the master cylinder were damaged during the bleed process. Old M/Cs do not like being extended in this way - the pedal pump method can over extend them.
964 RSA - Slightly modified PCA GT4 NASA GTS4 |
Thanks to all of you.
I will try to get a pressure bleeder and repeat the hole process.
K-Jetronic student
I opened my abs pump on a 964 c2 and used the power bleeder successfully to eliminate air from the system although it took several bleeds before the lines were clear of air.
On a C4 there is a slightly different abs system which requires a special bleed proceedure. |
