964 valves
Hello,
I have a 90 964 C4 and the valves are more clattery then my 92 964 or my *80's Carreras.
Does the engine have to be removed for a valve adjustment, I believe this is all it needs.
Has 94k miles.
Thank you,
Bruce
Old 11-09-2015, 01:32 PM
Easily done with the motor in the car.
'90C4
Old 11-09-2015, 03:32 PM
thank you very much
Old 11-10-2015, 07:12 AM
Valve adjustment, to me the most convenient way is to remove the side sheet metal and you will have easy access to intakes and exhaust valves.
Old 12-23-2015, 12:20 PM
fasterlaster's Avatar
Oh, and also remove the rear wheels. You may look at it like I did and say 'bah, I can work around this no problem' and you can. But by simply following the instructions where it clearly says 'remove rear wheel' made it so much easier. I can be stupidly lazy sometimes.
1974 Porsche 911 Targa w/ 3.2L
1989 Porsche 964 Carrera 4
Old 12-23-2015, 03:37 PM
