My BRAKE warning light goes pretty much every time I drive my car. It seems it happens 3-4 minutes after I get going, and it happens as I'm cruising or driving, not necessarily while braking (my brake fluid level is correct.)
What can I do to diagnose this problem? Thanks! |
Umm, probably need to check/replace your brake pads.
There is a sensor mounted on the pads that "warns" you when they are worn out.
Dave 2014 Cayman S (Awesome car!) 1991 911 Carerra (Semi Refined fun) 1986 911 Carrerra (Raw fun) sold 2001 Boxster S (Refined fun) sold |
There is a separate brake pad warning light.
Check your handbrake. There is a sensor below it that triggers the light.
Also check ur brake fluid level |
Or possibly the brake fluid level float switch? Another would be the brake pressure switch connections located under the front bonnet or the pressure switch itself.
Just my 2 Scheckles...Good Luck with Your Fix, Brother! Best Regards, Tony
90-964-cab |
Top off your brake fluid
| Tags |
| brake warning light |
