umop apisdn
Thanks everyone,
A gentle reminder of my last note from June. Quote:
Remember when I said you should all hang on to your failed units? well.... This little fellow was presented to me last week. Matt black anodised aluminium (anodized aluminum) module cap with ceramic inserts for electrical isolation and thermal management. More compact, less machining, no worries about connectors or case sealing, less obvious it is not stock etc. But logistically more complicated. - Machine off the donor cap, - snip the internal connections and skim the contact pads. - drop in the new module and reseal. Tolerances are tight so you will need to send your dead unit somewhere to have it modified etc. As always, still much to do, and I'll post updates as we have them.
Steve 1981 928S 4.7 ROW with KE3-Jetronic "Be the man your dog thinks you are." www.FrankenCIS.com |
I think this could be a profitable venture! Figure the 964 turbo production; both 3.3 & 3.6… roughly 5,000 units- every car will need this eventually. Even if 10% need it, that’s still 500 cars and $1,000/unit = $500k. The alternative if stand alone engine management program for about $50k/each car
That doesnt work to send off to you asap. Thank you kindly Helio Lopes
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo |
Dave |
Porsche was never known for its electronics and is a weak point still to this day.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others |
Actually, the 3 pin Bosch CDI, used until the late '70s, was very reliable and rarely failed. They typically failed because; 1. reverse battery connections 2. overcharging alternators 3. shorting the CDI coil signal while adjusting the idle. The later CDI (6 pin) fails because of a marginal output capacitor, and the result of hotter engine compartment temperatures (200F+), still not as hot as for turbos.
Dave Last edited by mysocal911; 10-27-2025 at 10:35 AM.. |
I’d take one just to put it on the shelf. I feel many others would do the same. Heck the factory will probably catch wind of this and buy a bunch as well.
I have been closely following the 965 market for over 25 years and although these are a failure point it isn't until recently within the past 5-7 years that we are hearing more and more about these failures. They built the cars well but how many other marques have this % of 30+ year old cars on the road with so few made? The lack of replacement parts is the issue and I don't think getting 30 years out of anything these days is that bad. I have had more electronics go on several 981's and newer Porsche's than I see EZ69's fail. I have helped a few out by supplying replacements for them but my well is now dry except for one spare. One was returned to Brumos for the #59 super turbo it came from. Porsche electronics have never been their strong point. But having anything that won't compromise the originality by cutting harnesses or makeshift compromises on these rare cars is a huge plus and we should be happy we have a potential alternative. I will wait to pass judgement on the product for now but I know of many 3.6T's which are still running their original EZ unit. In time they might need it but preventative maintenance and checking your coil output and reapplying the paste would be a good palce to start. My only concern with replacing anything Bosch right now is most of it is not good and there are some Chinese parts coming in which are horrible. So this might be a bigger concern in the future.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others Last edited by Cobalt; 10-28-2025 at 06:05 AM.. |
umop apisdn
Confidence in the extracted EZ69-01 ignition timing values is now 82%
subset of the data at the Porsche specified test points (Idle and 3K)
Sounds like a win! In fact you can probably adjust the curves to better than stock.
Right, but when do we actually see a real spark?
Dave |
umop apisdn
win or lose the finish line is getting closer by the day
![]() Fingers still crossed here for a win though!
Steve 1981 928S 4.7 ROW with KE3-Jetronic "Be the man your dog thinks you are." www.FrankenCIS.com Last edited by Reanimotion; 12-02-2025 at 04:00 AM.. |
umop apisdn
Happy holidays everyone!
Rendered primary maps for both the 01 and 02 units, Code:
Worshop manual supplement timing test page inspection/test values 1991-92 3.3 turbo P/N: 965 602 706 01 @ IDLE 1000 RPM with vacuum connected (est 650mBar) and throttle switch closed ignition timing is 0 degrees +/- 3 degrees @ 3000 rpm with 400 mbar ignition timing is 40 degrees +/- 3 degrees @ 3000 rpm with 1,750 mbar ignition timing is 21 degrees +/- 3 degrees Code:
NOT in Worshop manual supplement for 3.6 but should have been 1994 3.6 turbo P/N: 965 602 706 02 @ IDLE 1000 RPM with vacuum connected (est 650mBar) and throttle switch closed ignition timing is 1 degree +/- 3 degrees @ 3000 rpm with 400 mbar ignition timing is 39 degrees +/- 3 degrees @ 3000 rpm with 1,750 mbar ignition timing is 16 degrees +/- 3 degrees
I like what I see!
Dave |
