91 964 Wheels
Please help,
I'm really confused about wheel sizes, patterns, offsets. I just want to know if anyone could tell me whether 1978 Carrera original fuchs will fit a 1991 964?
Thank you very much.
Old 02-13-2017, 08:08 AM
no they wont.
Old 02-14-2017, 12:29 AM
All this information can be found doing a simple google search or a thread search on Pelican. SC wheels will not go on NB 964s. Stock offsets on a 964 are et.52 and et.55 (I believe). Stock SC is 15 and 22 (I believe). SC wheels mounted will stick out past the wheel well on a 964. These offsets are going off of memory and I cannot remember exacts at the moment.
Old 02-14-2017, 07:22 AM
Old 02-14-2017, 08:09 AM
Bill Verburg's Avatar
Originally Posted by mmoe View Post
Please help,
All 911 through at least 997 have the same 5 130 bolt pattern(exceptions being the cars w/ centerlocks). Wheels from earlier 911 will have the wrong ET for use on 964
for 964
6ET52.3 x16
8ET52.3 x16
205/55
225/50
or
7ET55 x17
8ET52x17
205/50
255/50
or for 964RS
7.5ET55x17
9ET55x17
205/50
255/50
or
for 964 Cup
8ET52x18
9.5ET47x18
235/645
265/645
Bill Verburg
Old 02-15-2017, 01:44 PM
Bill, did you type that out from memory, or do you have these posts saved in a doc, so you can just copy and paste each time someone asks??
Old 02-18-2017, 03:48 AM
Bill Verburg, I have a set of twist 993 wheels 8s and 10s is it possible to use them on my 964 before I buy tires for them I bought a set for my 1995 968 and they worked perfect without spaceers?
Old 03-05-2017, 01:03 PM
yes, assuming that they are 8ET52 & 10ET65, no spacers, they will look like this. These are 8ET50 & 10ET65 x18 w/ 245/35 & 275/35 x18 tires. You'd probably want to use 235/40 in front instead f 245/35
Bill Verburg
Old 03-05-2017, 04:45 PM
Thanks!!!!
That's the sizes�� Great pic.
I bought my car new took off secondary muffler iI kept muffler and hardware but have no clue what I did with the hardware to reinstall muffler. Do you have any of those items
Old 03-05-2017, 06:08 PM
Thanks!!!!
No on the parts
In the light of a new day I just remembered that the 10ET65 rears will need ~15 to 21mm spacers
I think that the green car has 21mm spacer Porsche part # #477.501.701
Bill Verburg
Old 03-06-2017, 03:53 AM
Kool..... thanks just the same
Old 03-06-2017, 04:04 PM
Ok on the spacers also
Old 03-06-2017, 04:06 PM
BILL,
Do you think 45mm bolts will work with the 21mm spacer and turbo twist wheel.
Old 03-06-2017, 05:43 PM
BILL,
Off the top of my head , no idea
you'd need to know the length of the stock ones, I may have that info somewhere but it's not immediately available.
Bill Verburg
Old 03-07-2017, 05:11 AM
If my coculations are correct 37.9mm
So I would add 21mm to that to get the correct length?
Old 03-07-2017, 10:33 AM
I changed to the 66mm studs and replaced my factory 16" wheels to 993 turbo twist 18" wheels the car stil have to much clearance between the top of the tire and the fender lip,.
In the last 15 years i may have put 10k miles on the car. With 3 kids in college I really don't care nor have a $1000 to put in suspension modifications.
Is it possible to lower the car with the factory suspension?
With my earlier models we just reset the torsion bars and ajusted the screws up front.
Old 03-09-2017, 04:47 AM
In a word, no, The front has a very small range of adjustment via the threaded section you can see here
In back there is a similar arrangement w/ very limited range
These are intended for corner balance adjustment not ride height adjustment
Bill Verburg
Old 03-09-2017, 05:37 AM
Thank you Bill for your help and knowledge.
Does anyone have the RSS9 used that are not wore out for cheap?
If not what should I expect to pay to accomplish my goal with the lease amount of money?
Old 03-09-2017, 02:30 PM
nickd's Avatar
Adding to Bill's info. The cheapest route is a combination of H&R springs and Bilstein B6 shocks&struts. That's a very typical setup and will give you a ~1-2" drop from the US ride height. Recognize that the spring collars on most front aftermarket spring/strut setups can be adjusted so low that you have no compression travel. Heights between RS and RoW generally allow reasonable suspension travel. Be smart.
The stock 964 wheel studs are 45mm, measured from under the head to the end of the threads. For aluminum lug nuts, the minimum is 21mm of thread engagement. If you use steel lug nuts, then the minimum is 14mm. By my measurements, these are the safe stud/spacers combos for our alloy nuts.
45mm stud, 0-1mm spacer
52mm stud (mine measure 50.5mm), 0-7mm spacer
66mm stud, 14-22mm spacer
Good luck!
1991 964 C4 Cabriolet - drop-top pylon destroyer
Old 03-10-2017, 08:20 AM
Thanks....
I am not that knowledgeable on these matters as you can see. But will try to figure it out. I was looking for the look that the green car in Bill's photo has.
When I took the 993 wheel off of my 968 and put it on my 964 it appeared to me it would have to go down maybe 3.5-4" to achieve the look of the green car in Bill's photo. Will the bilsteins and springs combination give me that look?
Thanks for you advice and help.
Old 03-10-2017, 10:46 AM
