4th gear shifting issues
Hey y'all, I've been hunting down an issue with my G96 box for months and cannot seem to figure out what is happening. Hoping someone here has had an experience like this or heard of something.
The problem Once the box gets up to temp I find it very difficult to shift OUT of fourth gear. It is just this gear, no other gears present any issue and going into gear is not a problem that I can perceive either. I will add that it is worse when the car is decelerating (so going from 4->3 is this most difficult) but you can feel it some accelerating 4->5. When it presented I had never noticed it until I switched over to a set of Numeric Cables and my initial assumption was they were installed incorrectly or not aligned quite right. Also since it is most noticeable when warm I also assumed it was something else and the solid cables were perhaps transmitting the issue more. I've since checked and had my indy check both at least 3x and everything seems exactly to what Numeric says for the install. Things to rule out
Banned
That's a puzzling issue. Since you've ruled out internal transmission problems and replaced the shift cables, consider exploring external factors:
Banned
1. Transmission mounts: Inspect and replace if necessary.
2. Crossmember and transmission tunnel: Check for any interference or misalignment. 3. Shifter assembly: Examine the shifter's alignment and condition. |
| Tags |
| 996 , clutch , g96 , gearbox |
