Battery Disconnection Questions
Hi,
I have a 2004 996TT. Its in storage for winter and wont be used for a couple of months, if I disconnect the battery and close the bonnet will I be able to open it again by using the power lead connection in the drivers (UK car) footwell that I use to open the bonnet when the battery is flat ? Thanks. |
You should be able to.
Rick 99 996C4 06 525XI 87 944S - Sold 77 924 - Sold |
Why not just leave the bonnet ajar?
1974 914 2.0 1980 911 SC 2002 996 Cabrio 2000 Silverado 2011 Golf |
Its stored in a communal garage.
Anyone know for sure, I dont what to try it and then find out there is no way to open the bonnet. |
Well, it ought to work since that's what it's intended for, but if push comes to shove, there should also be an emergency release cable under the front bumper.
thanks will give it a go !
If it does not work and you left the battery cover off what you can do is use a long screw driver. Connect the + end of the jumper box to the screwdriver and the - to a ground. Touch the screwdriver to the + post and pull the switch.
