engine specs/sizes.
Hi all , can anyone help me please.
Cant seem to find any sizes for my 3.4 m96 engine. 1What are the standard bore/cylinder sizes. 2What are the standard crankshaft big end sizes. 3What are the standard crankshaft main bearing sizes. Any info much appreciated.
engine type
naturally aspirated petrol Engine manufacturer Porsche Cylinders Flat 6 Capacity 3.4 litre 3387 cc (206.687 cu in) Bore × Stroke 96 × 78 mm 3.78 × 3.07 in Bore/stroke ratio 1.23 double overhead camshaft (DOHC) 4 valves per cylinder 24 valves in total maximum power output (DIN) 300 PS (296 bhp) (221 kW) at 6800 rpm Specific output (DIN) 87.4 bhp/litre 1.43 bhp/cu in maximum torque (DIN) 350 Nm (258 ft·lb) (35.7 kgm) at 4600 rpm Specific torque (DIN) 103.34 Nm/litre 1.25 ft·lb/cu3 Engine construction sump dry sumped compression ratio 11.3:1 Fuel system DME fuel inj. bmep (brake mean effective pressure) 1298.6 kPa (188.3 psi) Maximum RPM 7300 rpm crankshaft bearings Engine coolant Water Unitary capacity 564.5 cc Aspiration Normal Compressor N/A Intercooler None Catalytic converter Y |
